2002 Dodge Neon Hard to Shift when A/C is turned on
168,000 MILES • 4 CYL • FWD • MANUAL
NDNCHEIF
Shift cables replaced, now, in the morning when its cool, shifting is easy and smooth. After work, its hot and when I run the a/c, shifting becomes hard, it will not go in gear. Need to push in the clutch multiple times to engage gear at a full stop. When i turn off a/c, shifting is better, but not as easy as in the morning. What is the remedy for this problem?
Jun 20, 2008 at 7:19 AM
DOCFIXIT
  • 18,828 POSTS
REcheck the adjustment on shift cables see if in neutral they line up properly.
Jun 20, 2008 at 8:00 AM
