2002 Dodge Neon Fluid is fine. What could be the problem?
156,000 MILES • 4 CYL • 2WD • AUTOMATIC
KMAUL001
My power steering stopped working a couple of days ago. I checked the fluid and it is fine. The belt on the pump seemed a little lose but it was hard to tell. There is no screeching or an other noises when I try to steer my car. What could the problem be? Is there a way to check my power steering pump inexpensivly?
Mar 24, 2010 at 8:13 AM
BMRFIXIT
  • 19,053 POSTS
Check if the power steering pump putting out pressure
raise the RPM and check if that improve the steering
also suspect rack and pinion
Mar 24, 2010 at 11:08 PM
