2002 Dodge Neon Engine mount
90,000 MILES • 4 CYL • FWD • AUTOMATIC
RUSHY
I have a 2002 dodge neon se. It started vibrating and got really noisy at higher rpm. I noticed the upper and lower engine mounts were bad and replaced them. There is another mount right above the timing belt plate that seems to stop this noise if i from the inner tire well use a screwdriver to pry it upwards. I cant seem to find any parts number for this. Please help.
Oct 1, 2010 at 10:24 AM
  • 110,251 POSTS
Does this look like the mount?
https://images.2carpros.com/forum/automotive_pictures/249084_5_77.jpg
Oct 3, 2010 at 3:11 PM
RUSHY
No its actually the engine mount that connects to the timing belt cover. i got it done...Not an easy part to find
Oct 5, 2010 at 2:40 AM
  • 110,251 POSTS
Glad you found it. I wasn't sure which one you ment. Let us know if you have questions in the future.
Oct 5, 2010 at 3:11 AM
