2002 Dodge Neon Engine Light
45,000 MILES • 4 CYL • FWD • AUTOMATIC
MATTCROC
My girlfriends 2002 Dodge Neon's Engine light came on. When I took it to Auto Zone they said it was the power steering pressure system. It seemed to steer fine and smoothly to me but I do not drive it that often. The fluid level looked fine. Any idea's to what it could be or how serious?
Nov 23, 2008 at 2:11 AM
BMRFIXIT
  • 19,053 POSTS
Cycle key ON OFF ON OFF ON
read code in the odometer area (P ****)
and let me know what you have
if its the pressure switch, that is out, then the PCM will not recognize the pressure that it may cause the engine to stall at slow idle and tight corners
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 24, 2008 at 8:53 AM
