2002 Dodge Neon down shift "clunk " ?
MDCTLEW
Transmission problem
2002 Dodge Neon 4 cyl Front Wheel Drive Automatic 60xxx miles
when slowing down and the tranny shifts from 2nd down into 1st I get a hard "clunk " .
fluid level ok . anyone ???
Jul 29, 2008 at 9:44 AM
MMPRINCE4000
  • 8,548 POSTS
I would raise the vehicle, put on stands. Grasp tires and check vertical and horizontal movement (there should not be any). If OK, then remove wheel and inspect brakes, also inspect CV axles, making sure they are seated properly.
If you have any movement in wheel, check ball joints, struts, bearings, outer tierods and bushings.
Also inspect the motor mounts, looking for loose bolts, or torn/collapsed rubber.
Jul 31, 2008 at 1:49 AM
