2002 Dodge Neon dashboard
10,000 MILES • 4 CYL • 2WD • MANUAL
JUANELO77
on the panel the fuel,presure and millege gages don't work ,the emergency ligths are all on and there is a sign that reads " no bus"
Jan 13, 2010 at 1:24 AM
JDL
  • 16,098 POSTS
Welcome to the forum, you may need to get a dealership to properly diagnose your problem. I looked at service bulletins, nothing caught my attention. I looked at suggestions on a fix database, several said to replace the instrument cluster, a couple said the multiwire connector at the cluster can cause issues. The cluster is several hundred dollars, plus you may need a DRB111 scan tool to program the cluster, where applicable. I don't replace anything without trying to be sure of the problem.
Jan 13, 2010 at 3:00 AM
MIKEJP
I have a neon as well as for the gauges not working check this out. My gauges were not working soldering a few spots worked great no more problems.
Jan 13, 2010 at 4:25 PM
