2002 Dodge Neon BRAKE LIGHT GOES OFF AND ON
63,000 MILES • 4 CYL • FWD • AUTOMATIC
MIDDLEHOOK
If brake light goes on and off do i need brakes or just to fill brake fluid
Dec 10, 2009 at 12:17 AM
KJEAN001
I just had this problem happen to me. It's in the shop getting fixed right now. I have a 2002 Dodge Neon with 94,000 and the brake light kept going on and off, I ignored it for the first couple days but then it started to stay on. I added more brake fluid and it went away. Only for two weeks later it to come back on and stay on... DO NOT ADD BRAKE FLUID!!! Get it checked out!!! I brought it in and they took off my rear tires to check the brakes and my right rear brake shoe, drum and pad were completely saturated from the brake fluid leaking in there. Get it checked out just incase!!! It can save you a lot of money instead of adding it and having the same thing happen to you... Good luck!
Dec 18, 2009 at 2:52 PM
