Where is the bleeder bolt for the radiator located?
Mar 15, 2008 at 9:56 AM
BMRFIXIT
✓Experienced Mechanic
I don’t believe it has one
if you need to bleed the system run it until you have heat and then let it cool down and check coolant level and adjust run engine and check
good luck
