2002 Dodge Neon bleeder bolt
67,580 MILES • 4 CYL • 2WD • AUTOMATIC
KENNY0616
Where is the bleeder bolt for the radiator located?
Mar 15, 2008 at 9:56 AM
BMRFIXIT
  • 19,053 POSTS
I don’t believe it has one
if you need to bleed the system run it until you have heat and then let it cool down and check coolant level and adjust run engine and check
good luck
Mar 15, 2008 at 11:13 AM
