2002 Dodge Neon Antifreeze leaked into my transmission.
NKGAC60
Transmission problem
2002 Dodge Neon 4 cyl Two Wheel Drive Automatic
We use propylene glycol antifreeze will this harm the transmission? We flushed the transmission.
Apr 5, 2010 at 1:39 AM
CARADIODOC
  • 34,397 POSTS
Are you saying you put this in the transmission? Ethylene glycol is the proper antifreeze for the engine. It contains additives to neutralize the acids that naturally form in the coolant. Those additives prevent corrosion of the heater core, radiator, and other metal parts. Ethylene glycol also contains a water pump lubricant additive.
What you put in the radiator has nothing to do with the transmission.
caradiodoc
Apr 8, 2010 at 7:35 PM
MICAHCROWL
In this model there is a cooling system inside of the radiator for thr transmission. If you get a leak in either one the coolents will then mix. Change radiator and have your ststems flushed several times.
Apr 23, 2010 at 3:34 PM
CARADIODOC
  • 34,397 POSTS
You're right. Most cars are built this way. But the question is will the wrong coolant hurt the transmission. Any coolant in the transmission is bad, but the transmission will not be damaged simply from what is used for engine coolant.
caradiodoc
Apr 23, 2010 at 6:21 PM
