2001 Dodge Neon transmission cooler lines
165,000 MILES • 4 CYL • FWD • AUTOMATIC
DUANE S
i have lost all of my trans fluid, due to a cooler line coming off, my questiion is is that fitting threaded or is it part of the cooler so that i need to replace the whole cooler or just the fitting?
Jan 9, 2010 at 1:11 AM
SBHAWAIIAN
I have a 2000 and just replaced one line. just above the trany drain plate remove small radiator clamp. you might have to losen air filter box to get in there. on other end same deal 1/4" socket.
Use transmission line .30 ID. just above the trany plate also another line, same hose return line. I should have sprayed gunk on it before starting and washed area. the leaking fluid collected a lot of grime. important to set up clamps so you can get a good grip in tightening. Tight working area. sbhawaiian@hotmail.com for ?
Jan 28, 2011 at 11:28 AM
