2001 Dodge Neon power steering
101,000 MILES • 4 CYL • FWD • AUTOMATIC
FALLEN.ANGEL42069
While driving on a back road, my power steering started to go out around curves. I checked the fluid and the belt, but both were fine. I had to drive home approx. 150 miles. The next day, I was driving my husband to work and it went out completely. I could not move the car. He left work, took me home, and rechecked the belt. The belt and fluid are still fine, but the belt seems too loose, and the tensioner pulley appears to be twisted. Does this mean we just need to replace the tensioner pulley? Do we need to replace the entire tensioner? What about the belt, which is still good? Also, how do we go about doing this?
Dec 11, 2008 at 12:28 AM
ZACKMAN
  • 4,202 POSTS
With the engine running, look at the tensioner. If it doesn't move too much or violently, just replace the pulley. But if it is moving erratically, I suggest that you replace the assembly.
I have always replace the belt when I replace a pulley or tensioner. But it is up to you. If the belt is less than a year old, and you don't see any (much) cracks, and not glazed, you may re-use the belt. Otherwise, you should replace.
Dec 11, 2008 at 1:56 PM
