2001 Dodge Neon oil
190,000 MILES • 4 CYL • FWD • MANUAL
DICKLATELY
I went to change my spark plugs today and when I removed the plugs I found that the #2 and #4 cylinders were full of oil. The spark plugs and even the boots were covered in oil. My wife drives the car and said she never noticed anything wrong. I just had the oil changed at a shop, could they have added too much oil?
Mar 21, 2008 at 12:47 PM
SERVICE WRITER
  • 9,123 POSTS
Is it clean oil?
May be valve cover leakage. Get it cleaned off in that area and ablve it and keep an eye on it.
A quick lube place, anything is possible, would would be more apt to think they may have got a squirt off the mark than over filled it if it is clean oil. and if it dirtyier oil, probably leakage.
Mar 21, 2008 at 1:22 PM
BMRFIXIT
  • 19,053 POSTS
you need valve cover gasket
make sure you replace the o rings around the cylinder holes
Mar 21, 2008 at 1:23 PM
DICKLATELY
Which o-rings would those be?
Mar 23, 2008 at 10:00 AM
BMRFIXIT
  • 19,053 POSTS
the opening where the spark plugs check the red and green some valve cover gasket they do not include them in
https://images.2carpros.com/forum/automotive_pictures/99387_o_rings_1.jpg
Mar 23, 2008 at 10:22 AM
