2001 Dodge Neon odb
NJOYPOWELL
Engine Performance problem
2001 Dodge Neon 4 cyl Two Wheel Drive Automatic
i fixed the timing belt & water pump & now car wont start. do i need to use a odb scanner tool to reset computer
Mar 22, 2009 at 11:40 AM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:624bfdbee3="njoypowell"]Engine Performance problem
i fixed the timing belt & water pump & now car wont start. do i need to use a odb scanner tool to reset computer[/quote:624bfdbee3]
Did you double check the timing marks?
Did you also check to make sure all electrical connections are connected.
Mar 22, 2009 at 11:45 AM
