2001 Dodge Neon No spark to plugs
14,100 MILES • 4 CYL • FWD • AUTOMATIC
BASSER1922
Timing belt broke, 2.0L, changed belt, no compression or spark to plugs, changed engine due to bent valves, new engine has good compression, but still no spark to plugs and fuel smell is NOT present on plugs after cranking engine. P0743 code only error. It appeared to have "no spark" conditions after belt broke. Where do I start?
Apr 15, 2009 at 12:49 AM
BMRFIXIT
  • 19,053 POSTS
With key on do you have check engine light on (you should )
crank engine does the light go off (it should )
check ASD relay
Apr 15, 2009 at 2:53 PM
BASSER1922
ASD relay checks good, engine light remains on. Tested plugs - no power, tested connector to ignition coil - no power to Primary #1 or #2, but have voltage to ASD with ignition coil connector off checking connector voltage. Voltage does go to fuel injectors, however, no fuel on plugs. Looking more like voltage from ECM/PCM not getting there??
Apr 16, 2009 at 6:35 AM
BMRFIXIT
  • 19,053 POSTS
key on engine cranking does the check engine light stay on and if so check crank sensor and or replace
Apr 16, 2009 at 11:56 AM
