2001 Dodge Neon Horn
55,000 MILES • 4 CYL • FWD • AUTOMATIC
BLINDMANK
  • 5 POSTS
How do you replace the horn switch in the steering column on a 2001 Neon?
Feb 10, 2008 at 10:25 AM
BMRFIXIT
  • 19,053 POSTS
[quote:1e42ce948d="blindmank"]Electrical problem
2001 Dodge Neon 4 cyl Front Wheel Drive Automatic 55,000 miles
How do you replace the horn switch in the steering column on a 2001 Neon?[/quote:1e42ce948d]
did you check the clock spring
that may be the problem
as for the switch did you get the new one yet !
Feb 10, 2008 at 10:43 AM
BLINDMANK
  • 5 POSTS
[quote:b45966ec48="BMRFIXIT"][quote:b45966ec48="blindmank"]Electrical problem
How do you replace the horn switch in the steering column on a 2001 Neon?[/quote:b45966ec48]
as for the switch did you get the new one yet ![/quote:b45966ec48]
I have not got a swith yet-I checked the fuse, relay and horn itself and all are good so I assume it must be the swith in the steering wheel.
Feb 10, 2008 at 11:01 AM
BMRFIXIT
  • 19,053 POSTS
I would check if its the clock spring
they’re know to go bad
good luck
Feb 10, 2008 at 11:44 AM
BLINDMANK
  • 5 POSTS
[quote:c022c9a6b1="BMRFIXIT"]I would check if its the clock spring
good luck[/quote:c022c9a6b1]
Sorry-what is the clock spring and where is it?
Feb 10, 2008 at 9:37 PM
BMRFIXIT
  • 19,053 POSTS
[quote:6b45277d27="blindmank"][quote:6b45277d27="BMRFIXIT"]I would check if its the clock spring
good luck[/quote:6b45277d27]
Sorry-what is the clock spring and where is it?[/quote:6b45277d27]
it sits under the steering wheel
you have to take driver air bag out then steering wheel and you will see it
when you remove the air bag you can test the horn switch
Feb 11, 2008 at 5:12 AM
