How many quarts does the transmission take
134,500 MILES • 4 CYL • FWD • AUTOMATIC
ZOEY144
How many quarts does the transmission take when it is empty?
Jan 27, 2009 at 1:04 PM
OBXAUTOMEDIC
  • 3,718 POSTS
If you just changed the fluid and filter then I believe it take about 4 and 3/4 qts. Put 4 in start engine let run for about a minute then with foot on brake shift through all gears and back to park. Add additional fluid till 1/8th inch below ADD Mark. Run engine till reaches Normal Operating Temp recheck fluid fill to within Hot Range. DO NOT OVER Fill..........................................
Feb 24, 2021 at 10:12 AM
