The car backfires and sputters and surges up and down and the brake pedal is hard to push down.
Mar 4, 2009 at 2:34 AM
✓Experienced Mechanic
Hi:
It sounds like there is a vacuum leak at the brake booster. It is located behind the master cylender. There is a large vacuum hose going to it from the engine. If the hose is good, have the booster vacum tested. This problem will cause a backfire and loss of power assist for the brakes.
Let me know if you have other questions, and if this helps.
