2001 Dodge Neon brakes wont work after new brake pads and n
2001 DODGE NEON
ANDRESEN.123
Brakes problem
2001 Dodge Neon 4 cyl Front Wheel Drive 157000 miles
i have put new brake pads on my front two tires and on my right front tire my banjo bolt broke so i ordered a new bolt and replaced it and made sure the hole is lined up so the brake fluid will flow good, but when i press on the brakes they do not work, what is going on??
Oct 26, 2010 at 6:14 AM
KHLOW2008
  • 41,814 POSTS
Hi andresen.123,
Thank you for the donation.
Was bleeding done on the brake system?
Is there any pressure coming out of bleeder bolts?
Does the brake pedal increase in height when pedal is pumped a few times and held?
Oct 26, 2010 at 7:03 AM
