Monday, March 10th, 2008 AT 2:01 PM
My Niece's car stopped running and after I have checked it out I find it to be blowing the 15amp #10 fuse. The panel is marked for LDP ABS, PTU SOL, ENG RLYS, ENG MOD. I have disconected the ECM and it will still do it when turning the key to run, I have disconected the starter moter and it will still do it in run mode. I believed it to be a grounding problem but can not find a problem wire. The car is not equipped with ABS, so my question is what does PTU stand for and is this a probable cause? I have a chiltons manual (no PTU in Electrical Diagram), and it differs on the color of wires from #10 fuse. (It says it is a Dk Blu/wht wire, but in fact the wire leading from the fuse is Lt BLU/WHT).
