2000 Dodge Neon fuse
2000 DODGE NEON
113,825 MILES • 4 CYL • FWD • AUTOMATIC
JPDRUMZ1
The battery was dead so i removed it to charge it, when i put it back in to start it, i get an error messege "fuse", i checked all the fuses and all are good, it cranks over but wont start, please HELP!!!
Dec 1, 2009 at 4:22 AM
JDL
  • 16,098 POSTS
Welcome to the forum, have a helper crank it, while you check for spark at the plugs. If no spark, check primary voltage at the coil pack, engine cranking. Dark green wire with orange stripe is primary voltage, use testlite.
Dec 1, 2009 at 6:01 AM
CARADIODOC
  • 34,346 POSTS
Are you aware there's two fuse boxes? The Power Distribution Center is under the hood, next to the battery. The Fuse Block in in the dash.
caradiodoc
Dec 1, 2009 at 8:02 PM
