2000 Dodge Neon wont shut off with key
MHETHORN
Electrical problem
2000 Dodge Neon 4 cyl Front Wheel Drive Automatic
When you turn the ignition off and pull the key the engine will continue to run. I had to pull the relay under the hood in order to shut it off. What could be the probable cause for this?
Sep 13, 2008 at 5:39 PM
BMRFIXIT
  • 19,053 POSTS
Suspect ignition switch
also if u have remote starter with and alarm system I would check it to
any rewiring was done on it need to be rechecked
Sep 14, 2008 at 2:58 AM
