2000 Dodge Neon unsure
105,235 MILES • 4 CYL • 2WD • MANUAL
00NEON
ok, my car will not start, the power locks won't work, the radio won't turn on, my cluster doesn't work, no turn signals, and right before this all happend my obd on the dash said "no bus" and the keyless entry won't work. i have checked the fuses and they are all good, even under the hood. im thinking PCM, any clue?
Mar 1, 2008 at 7:24 AM
BMRFIXIT
  • 19,053 POSTS
what is the code ?
check battery and relays
check BCM for codes
BCM 1st
Mar 1, 2008 at 12:29 PM
