2000 Dodge Neon starting
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAWSON1961
will a neutral \ park switch make it stall when put into gear
Oct 22, 2009 at 4:48 PM
  • 75,988 POSTS
Hi dawson1961 and TY for the donation
Park and Neutral switch is just to prevent the vehicle from starting other than P/N position it will not cause the engine to stall.
This problem could be caused by the following the idle air control motor, throttle position sensor, manifold absolute pressure sensor, also check the ignition timing and fuel pressure
Oct 22, 2009 at 6:05 PM
DAWSON1961
yea but now it won't cranck at all had the starter checked it good and changed the ignition switch
Oct 22, 2009 at 6:30 PM
  • 75,988 POSTS
Double check the battery and connection if okay
Check fuse no. 9 30amp if okay have helper hold key to start position and check for power at the starter motor small terminal brown wire -do you have power? If so it points to a bad starter if not swap or replace the starter relay and tell me what happened.
Oct 23, 2009 at 2:08 AM
DAWSON1961
checked brown wire to starter no power when crancking changed relay still no power
Oct 23, 2009 at 11:22 AM
  • 75,988 POSTS
Check and test the P/N switch see below if it checks out it coming from the ignition switch
TEST
The park/neutral starting switch is the center terminal of the three terminal switch. It provides ground for the starter solenoid circuit through the selector lever in PARK and NEUTRAL positions only.
To test switch, remove wiring connector from switch and test for continuity between center pin of switch and transaxle case. Continuity should exist only when transaxle is in PARK or NEUTRAL.
Check gearshift cable adjustment before replacing a switch that tests bad.
REMOVAL
Unscrew switch from transaxle case allowing fluid to drain into a container. Move selector lever to PARK, then to NEUTRAL position, and inspect to see the switch operating lever fingers are centered in switch opening.
INSTALLATION
Screw the switch with a new seal into transaxle case and tighten to 33 Nm (24 ft. lbs.) . Retest switch with the test lamp.
Add fluid to transaxle to bring up to proper level.
The back-up lamp switch circuit is through the two outside terminals of the three terminal switch.
To test switch, remove wiring connector from switch and test for continuity between the two outside pins.
Continuity should exist only with transaxle in REVERSE position.
No continuity should exist from either pin to the case.
Oct 23, 2009 at 2:04 PM
