2000 Dodge Neon
HMH_LAW
  • 2000 DODGE NEON
  • 4 CYL
  • 68,400 MILES
Hello!
I started the car this morning, put it in reverse, turned on front and rear defrosters on full blast and the car shut off.
Saturday, October 25th, 2008 AT 8:27 AM
BLACKOP555
  • 10,371 POSTS
Did it restart? Once restarted did it reverse just fine? Or did you have to turn off the blowers.
Need you to reply before I start to infer with what is wrong.
Saturday, October 25th, 2008 AT 9:49 AM
HMH_LAW
It restarted fine, but the blowers must be off.
Saturday, October 25th, 2008 AT 1:16 PM
BLACKOP555
  • 10,371 POSTS
Try charging your battery full and make sure the connections are tight and secure same for the alternator.
I have a feeling that with the high energy drain that the battery is trying to charge and causing a high demand on the alternator causing the engine to loose its power and stall out at the low speeds.
Saturday, October 25th, 2008 AT 2:33 PM
