2000 dodge neon problem
SHOOTER11
my question is what is a bubbling sound after u park the car and its off (automatic) ..is it an oil problem?
part two: how can u quick fix a starter problem to get it going.. please help thanks
Feb 28, 2007 at 4:19 AM
  • 75,988 POSTS
1 Bubbling-sounds like engine overheating
2. Stater-what is wrong with it-won't turn over/clicks/or nothing happens when key is in start position.
Feb 28, 2007 at 4:29 AM
SHOOTER11
it just makes 1 click .. it has power
Feb 28, 2007 at 5:08 AM
  • 75,988 POSTS
I would say start at the battery-clean it up and make sure its got good and tight connection. BTW how new is the battery
Feb 28, 2007 at 5:12 AM
SHOOTER11
battery clean up didn't seem to work. battery is fairly recent is ok. how do i make sure the connections are tight?
Feb 28, 2007 at 5:32 AM
  • 75,988 POSTS
[quote:c0ab1834ee="shooter11"]battery clean up didn't seem to work. battery is fairly recent is ok. how do i make sure the connections are tight?[/quote:c0ab1834ee]
Load test the battery to check its condition-maybe the electrical pressure is low and unable to crank the engine over due to a malfunctioning alternator.
Feb 28, 2007 at 5:58 AM
SHOOTER11
thanks i'll have to do that tonite.
have a good one
Feb 28, 2007 at 6:10 AM
