My question is what is a bubbling sound after u park the car and its off (automatic). Is it an oil problem?
part two: how can u quick fix a starter problem to get it going. Please help thanks
Wednesday, February 28th, 2007 AT 12:19 PM
MECHANIC
1 Bubbling-sounds like engine overheating
2. Stater-what is wrong with it-won't turn over/clicks/or nothing happens when key is in start position.
SPONSORED LINKS
Wednesday, February 28th, 2007 AT 12:29 PM
SHOOTER11
MEMBER
It just makes 1 click. It has power
Wednesday, February 28th, 2007 AT 1:08 PM
MECHANIC
I would say start at the battery-clean it up and make sure its got good and tight connection. BTW how new is the battery
Wednesday, February 28th, 2007 AT 1:12 PM
SHOOTER11
MEMBER
Battery clean up didn't seem to work. Battery is fairly recent is ok. How do I make sure the connections are tight?
Wednesday, February 28th, 2007 AT 1:32 PM
MECHANIC
Load test the battery to check its condition-maybe the electrical pressure is low and unable to crank the engine over due to a malfunctioning alternator.
