2000 Dodge Neon Power steering problem
99,777 MILES • 4 CYL • FWD • AUTOMATIC
MZAWOL07
  • 5 POSTS
Hello there I recently had a problem with my power steering pump first in 8 years of owning the car, when the really cold weather come in(Illinois) the power steering pump started to mess up. So I had it changed, it worked for about 2 months (with loud noise and i hated driving the car, but it worked with out any problems other than the noise) so after two months of driving it went out again, i had it changed again, and same thing is happening now, i found out that in the reservoir there is foam forming when i drive or move the wheel right to left. Once I open the cap for the reservoir the air goes away and there is nothing but fluid, then it works good fro about 3 min or so, depends how many times i turn the wheel right or left. And i don't know what is causing it to foam / and i don't know how to make it stop. Thanks.! ps. my mechanic told me to wait it out and the air will go away after couple days well its been a week now and still same thing.
Mar 2, 2008 at 6:08 AM
BMRFIXIT
  • 19,053 POSTS
you should ask them to bleed the system for you
they had no problem taking your money
Mar 7, 2008 at 10:57 AM
MZAWOL07
  • 5 POSTS
So you think this might help me? Cuz the pump is making noises right now, and I hate it. U think bleeding the system might help it? or should i get it flushed?
Mar 10, 2008 at 8:29 AM
BMRFIXIT
  • 19,053 POSTS
If they can not get the pump to quite down for your liking then I would ask them to replace it .
the pump defective and you need to have a new one
since they just did it
they should help you
when you pick the car up it should be running noise free
if not then the job was not done correct and they need to have it fixed to your liking
good luck
Mar 10, 2008 at 9:54 AM
MZAWOL07
  • 5 POSTS
lol , ok i see, thanks. so the only reason it is making the noise , its defective or it still has air in the hoses? correct?
Mar 10, 2008 at 1:45 PM
BMRFIXIT
  • 19,053 POSTS
AIR should be gone by know
Mar 11, 2008 at 5:36 AM
MZAWOL07
  • 5 POSTS
ok sorry for no response i was too busy with the mechanic. So he finally got it fixed last this Friday the car works. well did work, until i drove it on 3/23/08 and the rpms went around 5k then when i came to a stop, it was hard to turn the wheel again. Do you have any idea why it would do that? thanks.
Mar 23, 2008 at 10:55 AM
BMRFIXIT
  • 19,053 POSTS
I’m sorry to say that
but its time to get yourself a different shop
let them take a look at it for you
enough is enough !!!!
Mar 23, 2008 at 11:02 AM
MZAWOL07
  • 5 POSTS
ok thanks for your help.
Mar 23, 2008 at 12:17 PM
