2000 Dodge Neon please help on idle issues!!!!THANK'S
148,000 MILES • 4 CYL • FWD • AUTOMATIC
TSOG29
  • 6 POSTS
hello and thank you in advance for looking through this. i have a 2000 neon i just bought for my son and i replace the timing belt, water pump, alt.belt, powesteering belt, upper and lower engine mount, trans fluid and filter and did a full tune-up. my problem is that the car runs really good, engine sound really great and shift fine. when i come to a stop, the idle goes down a little and the whole car vibrates, when that happens i put in neutral and put it back in drive. the vibration stop. i cleaned the throttle body really good and clean the iac valve but no luck. it's not throwing any code. i know i did the timing right. i check for a vaccum leak only found one but that did no solve the problem. i do a lot of side job on cars and this really is giving me a head ache. im thinking of replacing the iac valve but don't know if that will help. any reply or help please.
Aug 27, 2009 at 2:28 PM
TSOG29
  • 6 POSTS
[quote:1d435aa881="tsog29"]Engine Mechanical problem
2000 Dodge Neon 4 cyl Front Wheel Drive Automatic 148000 miles
hello and thank you in advance for looking through this. i have a 2000 neon i just bought for my son and i replace the timing belt, water pump, alt.belt, powesteering belt, upper and lower engine mount, trans fluid and filter and did a full tune-up. my problem is that the car runs really good, engine sound really great and shift fine. when i come to a stop, the idle goes down a little and the whole car vibrates, when that happens i put in neutral and put it back in drive. the vibration stop. i cleaned the throttle body really good and clean the iac valve but no luck. it's not throwing any code. i know i did the timing right. i check for a vaccum leak only found one but that did no solve the problem. i do a lot of side job on cars and this really is giving me a head ache. im thinking of replacing the iac valve but don't know if that will help. any reply or help please.[/quote:1d435aa881]just bought a iac valve and did not have any luck at all. so im still trying to find the problem for now.....wish me luck....
Aug 28, 2009 at 3:37 PM
VALENTINE37012
My Neon does the same thing as you discribed. Change the Power Steering Switch. It controls the idle.
Feb 23, 2010 at 3:14 AM
DOINITMYSELF
  • 5 POSTS
Hi my 2003 neon is doing the same thing. It drives great but when at a stop it will idle rough? I put it in neutral and it stops, it doesnt die or anything like that but just very annoying. I have changed the upper and lower motor mounts spark plugs and wires. If you find out what the problem is please let me know.
Thanks Ken
Jul 22, 2010 at 6:55 PM
