2000 Dodge Neon P1490
2000 DODGE NEON
109,000 MILES • 4 CYL • FWD • MANUAL
DAVIDCBROWN
I have a trouble code P 1490. I know this is the cooling fan relay. I replaced the relay, but still get the code. The fan is coming on and off as it should. What else could be causing this?
Oct 20, 2009 at 6:10 AM
BMRFIXIT
  • 19,053 POSTS
Possible wiring need to check ,
do the wiggle test
do you have a scanner that you can hook up to the PCM and turn the fan on and do the wiggle test looking for an open wire or short
Oct 20, 2009 at 8:58 AM
