2000 Dodge Neon oxygen sensors
249,700 MILES • 4 CYL • FWD • MANUAL
RUSSHA686
i have a 2000 chrysler (dodge) neon 2.0 litre sohc, 5spd.
check engine light is on
i did the ignition key (on-off-on-off-on-off) trick
the following codes displayed themselves
P0134
P0135
P1684
i was wondering which of the oxygen sensors should i replace first
or should i just replace both before and after the catalyst converter and be done with it
Jul 24, 2008 at 5:21 PM
SERVICE WRITER
  • 9,123 POSTS
The first two codes are both related to the front o2.
The last one sounds like a communication error of some sort, but I don't have info on that one.
You can have the O2 scoped, but it might be the same cost to just replace it.
I would do a carbon cleaning on the engine first if it were mine.
Jul 24, 2008 at 10:46 PM
