2000 Dodge Neon Overheating
100,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRIS241
Having a problem with my Dodge Neon, 100 k, Just lately the car has been running hot in 25 degree temp. Goes up to about 3/4 of the way on the gauge. The heat coming out of the vents comes out really hot, almost to unbearable. But, when I idle the temp goes way down on the heat coming out of the vent.
There is no smell of anti freeze anywhere.
Feb 29, 2008 at 10:14 AM
MERLIN2021
  • 17,250 POSTS
Check all, cooling fan, does it come on? Coolant level, it might be low...thermostat, might be stuck, and last the waterpump impellers may be disolved to the point pump needs replacing, start with coolant level...
Feb 29, 2008 at 10:17 AM
