Electrical problem
2000 Dodge Neon 4 cyl Two Wheel Drive Automatic
We have a 2000 Dodge Neon where only the high beams works. We've checked the lights to ensure they are both high/low beam bulbs, have replaced the headlight switch located in the steering columun and ensured the fuses are functioning properly. We have checked all electrical contacts to make sure there is sufficient electricity to the important areas of the engine. However, when the lights are turned on, only the high beams work
Oct 16, 2010 at 5:34 AM
