power is good fuel is good the ignition coil is good but no spark ,what can I check please???
Oct 8, 2010 at 2:07 PM
JDL
✓Experienced Mechanic
Engine cranking, check for voltage at the dark green wire with orange tracer, that is primary voltage to the coil pack, same wire supplies voltage to injector/s, check them both for voltage, that voltage comes from the asd relay. The relay may not be faulty? If the computer doesn't see the proper cam and crank signals, it won't ground the relay.
