Door Fuse Message
MOMMMY25
How can I replace the door fuse? The light won't turn off, and my battery is being drained. Is it expensive?
Dec 11, 2008 at 12:59 PM
MORTICAR
  • 46 POSTS
It sounds like the door jam switch is bad.It is located in the door jamb. It is a quick cheap fix and it can be done in a few minutes. Open your door on the car and where the latch on the frame of the car is a push in type switch. Loosen the screw that holds in it and simply unplug it until you can get the new switch. I recommend putting electrical tape around the plug and hanging the tape out the hole and reinstalling the switch to hold it in place so the plug doesnt drop into the frame of the car. Hope this Helps MORT
Dec 13, 2008 at 5:32 AM
SFERGUSON2006
Displaying message on the dash that a "Door Fuse" and the lights on the rear view mirrors stay on. I have to set the on/off switch for the lights to halfway on/off. Is there a fuse for this problem or is this an electrical problem.
Thanks.
Mar 20, 2019 at 10:21 AM (Merged)
ZACKMAN
  • 4,202 POSTS
Electrical problem with your door ajar sensor (a part of your entry module), located under the center dash.
