2000 Dodge Neon Dashboard Gauges Fail
RYAN TURLEY
my neon has 55000 miles on it. It always runs fine but when it is hot outside the dash board sometimes does not work. the speedometer and tachometer, temp gauge stay at the bottom. The engine, airbag, and another red circle light stay on. The car runs fine but I can't tell how fast i'm going. While i'm driving the dash will shift from working fine to not at all. I think something must be loose but I do not know where to look.
Apr 20, 2006 at 1:34 AM
LOSONE
  • 1,616 POSTS
Remove the gauge/dash assy and clean the plig in connections with a fine pencil eraser. . it should work fine. A typical neon problem. Good luck
Apr 20, 2006 at 2:10 AM
RYAN TURLEY
I pulled the assembly out and cleaned connections but I am still having the same problem and other ideas.
May 2, 2006 at 11:37 PM
LOSONE
  • 1,616 POSTS
Well, it was worth a try. As an off chance, find the gauge fuse and replace it even if it looks good. Look at the prongs and see if they are corroded.
The only next step is to replace the cluster from a salvage yard. It shouldn't cost more than $50.00. Good luck
May 3, 2006 at 12:56 AM
Suggested Repair
Clean the instrument cluster plug connections, then check and replace the gauge fuse and inspect its prongs for corrosion. If the gauges still fail, replace the cluster with a used unit from a salvage yard.
Conversation Summary
A 2000 Dodge Neon with 55,000 miles intermittently loses the speedometer, tachometer, and temperature gauge when it is hot outside, while warning lights stay on and the car still runs. Cleaning the cluster connections did not fix it. The expert then suggested replacing the gauge fuse even if it looks good, checking the prongs for corrosion, and replacing the cluster from a salvage yard if needed.
