2000 Dodge Neon Check Engine light
WOOKIEOWNS33
Engine Mechanical problem
2000 Dodge Neon Front Wheel Drive Automatic 112000 miles
So my question to anybody who can solve this mysterey is, I have a check engine light on my 2000 plymouth neon and the reason that I have been told is because it sputters when changing 1st to second gear even though its an automatic. You can feel it struggle to get to second gear but it does it. And for that I am scared to get the car inspected because I live in Ny and with a check engine light its an automatic fail. Does anybody know what I can do to get my check engine light off so I can pass inspection
Sep 2, 2008 at 6:45 PM
BMRFIXIT
  • 19,053 POSTS
When check engine light on car computer have stored t trouble code in it and u need to get the code
codes will pin point u to the troubled area
u can scan the system for codes
or try self TC diagnose cycle key ON OFF ON OFF ON read codes in the odometer area(P####)
let me know
Sep 2, 2008 at 11:10 PM
WOOKIEOWNS33
Well i tried doing what you told me and I didnt get anything out of it because my check engine light disappeard now. There is a part on my odometer that says fuse which i understand basically means there is a bad fuse somewhere but i appreciate the help given me and i will remember that in the future. Thank you very much
Sep 3, 2008 at 4:33 PM
