My brake light came on and I checked the fluid and it was empty. I filled the resevoir and pumped the brakes, I check the brake pads and rotors and they are fine. The brake light went out after I put fluid in but now the reservoir is empty again and I can not detect a leak under the car and I don't know what to check to fix the problem. Can you help?
Sep 28, 2009 at 2:00 PM
