2000 Dodge Neon BRAKE FLUID LEAK
VALENESTLOUIS
Brakes problem
2000 Dodge Neon Engine Size unknown Four Wheel Drive Automatic 98801 miles
MY BRAKE FLUID MAY BE LEAKING I BEEN PUTTING FLUID IN IT AND AFTER 2 WEEKS THW BRAKE LIGHT KEEPS COMMING ON WHAT SHOULD I DO
Mar 26, 2008 at 1:18 PM
SERVICE WRITER
  • 9,123 POSTS
Find the leak!
While someone is inside, pressing on the brake pedal, your going to be on the ground looking underneath it until you see dripping. Pay close attention to the center of the car primarily from the engine to the rear seat area. The lines ten to rot out there on these because of the way the manufacturer designed them.
IF you see nothing, look at the rear wheel area. On the back side of the brakedrum is a backing plate. At the bottom of it you may leakage or see fluid spun around the inside of the tire.
Mar 26, 2008 at 1:29 PM
