2000 Dodge Neon Air Bag Light
2000 DODGE NEON
116,000 MILES • 4 CYL • FWD • AUTOMATIC
DAVID COONEY
The Air Bag Light came on and stays on, also the horn quit working at the same time. I check the fuses and reset the computer by disconnecting the Positive cable for 30 min. I also replace the relay. What else or what do I need to do to fix this problem? The car has always had lights come on and stay on at different times for the past three years, always a fuse or a reset worked. The car runs perfectly other wise.
Sep 19, 2008 at 12:15 AM
2CARPRO JACK
  • 11,533 POSTS
Air bag light have to be reset with a scan tool, and they wont go out unless the proper repairs are made.Since your horn went out as well, I would guess the "clcokspring" is bad. This is the contact between thes teering wheel adn the column that allows the wheel to turn without wires being in there.You will need to have the airbag system scanned to be sure
Sep 19, 2008 at 1:23 AM
