200 dodge neon
DODGEMAN2
hi i have a 2000 dodge neon highline it has 110000 miles on it and i am having misfire problems i replaced the coil with a msd ignition one new spark plugs and wires and upgraded my gas to mid octane and it still says the same thing on the check engine code can you help me out is there anything else i could look at it does overheat sometimes mostly when i set still awhile with it idling but the fan works fine.oh it's a five speed.
Jun 23, 2007 at 4:41 AM
JJCOM229
Well, here is the bad news first: Your not alone and if you take it to the dealer they ill charge about 150.00 to replace plugs and ires and the light ill come on again at about 28 miles. Now the badder (?) news: hen Mine did this it turned out it was the timing belt slipping and the belt went while I as driving so the engine is a mess right now.
The good news: the parts for the repair of the timing belt cost about 70.00 total. The job, if you follow chiltons AND get the correct Balancer puller from AutoZone (rents for 60.00 here), will take about 5 hours to replace yourself. You'll also needs floor jack stands and at least 1 floor jack to simplify things. Don't bother with the cheaper 3 jaw pullers you find, they won't work because of the design of the balance heel and how it is mounted. Also, don't bother pulling the engine mount on the passenger side from the body, it won't help and it's a pain to put back.
Good Luck
Jul 14, 2007 at 2:45 PM
