1999 Dodge Neon water pump
SDPARSONS83
Other Category problem
1999 Dodge Neon 4 cyl Wheel Drive Type unknown Automatic 143000 miles
What is the price range of getting water pump replaced at shop? How difficult would it be for "shade tree" mechanic?
Dec 12, 2007 at 12:18 PM
BMRFIXIT
  • 19,053 POSTS
[quote:4f96d7ae35="sdparsons83"]Other Category problem
What is the price range of getting water pump replaced at shop? How difficult would it be for "shade tree" mechanic?[/quote:4f96d7ae35]
timing belt should be replaced with the pump
look to spend 375 to 450 $
about 3 shop hrs + coolant + t belt + w/pump
Dec 12, 2007 at 12:25 PM
XERXIES
  • 10 POSTS
hey there,
did the water pump on my 95 neon and its a little bit of work, not to metion you have to have a gear puller 3 arm type. the two arm type is junk.
if your confident in your ability, go for it. but you will also have to change the timing belt wich is a little tricky. payed about 78.00 for my pump but if you get a garage to do it, 300.00 - 400.00 dollars
im just a shade tree too and it wasnt that bad.
ha ha of course there was a few choice swear words in the job too. ha ha good luck
Dec 12, 2007 at 12:43 PM
