1999 Dodge Neon valves
STEVOSKI
Engine Mechanical problem
1999 Dodge Neon 4 cyl Front Wheel Drive Manual
how am i supposed to remove and reinstall the valves on a dohc neon ive tried evrey tool offer by every auto parts store (which is very limited) ive asked many people who supposedly have automotive experiance i have resorted to using a old scholl c- clamp style valve compressor with a 1/2 drive socket jamed in it but that only seems to work one a few valves i was wondering what the proper valve spring compressor is and how i can get ahold of one
Nov 20, 2008 at 9:56 AM
  • 31,937 POSTS
Hi there ,
This type of valve set up is a real pain, there will be a special factory tool to do this, as you have found out there is no easy way to do it, i am unsure if there is a readily available after market compressor that will do the job, may be contact a head repairer and see what they use.
mark (mhpautos)
Nov 20, 2008 at 10:10 AM
