1999 Dodge Neon Timing
ANSONELVIS
  • 1999 DODGE NEON
Engine Mechanical problem
1999 Dodge Neon 4 cyl Manual 120000 miles
Let my buddy drive my manual 99 dodge neon, right after just spending 500 bucks replacing water pump and all timing components, pulleys, etc. He brought it back not running - the mechanic who did the work said after inspection that it seems the car was dropped into a low gear at a high rate of speed (60-80 mph) sheering the bolt and mangling the belt - just makes a whining noise when you turn the key, timing belt and housing look like a dog chewed them up, am I out my car? The mechanic is replacing the timing kit under warranty, please tell me it will all be just fine, don't loan your car out! Is this the case?
Sunday, April 4th, 2010 AT 10:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The 2.0 Liter SOHC and DOHC engines used in the Neon are interference engines. If the timing belt broke while driving there is about a 6 in 10 chance a valve came in contact with the piston. The only way to know for sure is to replace the belt and perform a compression check to see if any valves are not sealing
Sunday, April 4th, 2010 AT 10:34 PM
