1999 Dodge Neon stalling problem
130,000 MILES • 4 CYL • FWD • AUTOMATIC
DROOPY
i have a 99 neon at times it will quit like you turn off the key if you try to start it up it wont wait 5 min an it will start right back up i have tried a coil pack with no change
Jan 8, 2008 at 11:04 PM
2CARPRO JACK
  • 11,533 POSTS
HAve you had it scanned for codes? Could be a crank or cam sensor shorting, but have the PCM scanned to see first.
Jan 9, 2008 at 4:33 AM
DROOPY
[quote:02cca3e828="2CarPro Jack"]HAve you had it scanned for codes? Could be a crank or cam sensor shorting, but have the PCM scanned to see first.[/quote:02cca3e828] there are no codes on it
Jan 9, 2008 at 8:32 AM
2CARPRO JACK
  • 11,533 POSTS
next time it dies, need to test it for spark and fuel pressure to see what is missing
Jan 9, 2008 at 9:32 AM
