1999 Dodge Neon Rod Bearing Lubrication
1999 DODGE NEON
184,000 MILES • 4 CYL • FWD • MANUAL
POWERR
I recently had the head off of my 2.0 litre DOHC engine to replace a burned valve. Within 100 Km later 2 rod bearings turned. They got noisy and the oil lamp flickered at low rpm. I just replaced them and I'm hoping that will fix the problem as the oil light seems fine now. How is oil supplied to the crank. I took the valve cover off and all the head parts appear to be o.k. and lots of oil coming up to the head elements.
Mar 2, 2009 at 3:13 AM
  • 110,244 POSTS
Hi:
the oil is supplied by the pump through journals in the crank.
Mar 12, 2009 at 8:25 AM
