1999 Dodge Neon Low pressure port location.
157,400 MILES • 4 CYL • FWD • AUTOMATIC
99NEON
I have a 1999 Neon with the common 2.0[img:3802d3fd7b]http://www.2carpros.com/forum/automotive_pictures/161578_IMG_1744_1.jpg[/img:3802d3fd7b] litre SOHC 16 valve engine and recently the a/c has begun to blow warm. I want to recharge it and seal any leaks but am not familiar with wich is my low pressure port for charging. Both ports on the top right side of the engine compartment have black caps. Any direction here or tips would be kindly appreciated.
Regards,
Wayne Roberts
1999 Dodge Neon
Feb 23, 2008 at 6:14 AM
BMRFIXIT
  • 19,053 POSTS
take the cap off they are two different size
the small one is the low
any how the connector will not fit on the high side
if you had bought the kit
Feb 23, 2008 at 7:21 AM
99NEON
Thank so much for the quick reply. Will become a donater for sure with this polite fast help.
Thanks......
Wayne
Feb 23, 2008 at 7:38 AM
