1999 Dodge Neon head gasket
1999 DODGE NEON
96,000 MILES • 4 CYL • FWD • AUTOMATIC
PEDALTHERE
  • 5 POSTS
original problem, leaking oil from the back right corner below the head gasket. Went in replaced the head gasket , car wouldn't start but saw antifreeze in oil. crap, tore down again checked head and had resurfaced, replaced head gasket/bolts. Car runs but still has antifreeze getting in the oil. Have torn down a third time and had the head pressure checked and flatness checked, flatness checked the block, Mechanic at the shop said he didn't see anysigns of failure in the head gasket? What could it be?
Mar 10, 2008 at 5:47 AM
MERLIN2021
  • 17,250 POSTS
Has the block been cjhecked for cracks?
Mar 10, 2008 at 5:59 AM
PEDALTHERE
  • 5 POSTS
No, the block has not been checked but it originally didn't show signs. I don't see how the block could of cracked since it hasn't been run except at idle. There's never been any time it's been left with water only in it for a freeze situation. Is there anyway to test without removing it?
Mar 10, 2008 at 6:21 AM
MERLIN2021
  • 17,250 POSTS
https://images.2carpros.com/forum/automotive_pictures/62217_Head1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Head2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Intake1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Intake2_1.jpg
Bolts 7, 8, 9, 10 Are the SHORT bolts! Get all new bolts, they may have lost sealing and gripping ability!
Mar 10, 2008 at 7:07 AM
PEDALTHERE
  • 5 POSTS
All the above was followed. Anything else that it could be?
Mar 10, 2008 at 10:36 PM
2CARPRO JACK
  • 11,533 POSTS
You compare head gaskets to be sure you have the correct one?
Mar 11, 2008 at 4:54 AM
PEDALTHERE
  • 5 POSTS
Yes, the gasket was correct
Mar 11, 2008 at 11:56 AM
2CARPRO JACK
  • 11,533 POSTS
Merlin may have hit it with the long/short bolt idea. No sealing power if the bolt is bottomed out
Mar 12, 2008 at 12:42 AM
PEDALTHERE
  • 5 POSTS
no, the bolts were new and the short bolts were in the corners, There's at least 3 inches difference, you wouldn't be able to make that mistake.
Mar 12, 2008 at 12:49 AM
JOHNYPHANTOM
  • 37 POSTS
if im not mistaken pressure checking the head might not show a crack , magnafluxing will though , also it could be an intake gasket leak
Mar 12, 2008 at 3:27 AM
MERLIN2021
  • 17,250 POSTS
You might want to have a ppek at the threads in the block...if damaged you may need to helicoil them...
Mar 12, 2008 at 8:12 AM
