1999 Dodge Neon fluids
75,000 MILES • 4 CYL • FWD • MANUAL
MCENTRINO
is the brake fluid and the clutch fluid in the same resovoir??
also how and when should i change the manual transmision fluid.
Sep 16, 2010 at 1:42 AM
WRENCHTECH
  • 20,758 POSTS
This car doesn't have a hydraulic clutch. It uses a clutch cable instead.
The transmission has a fill plug and a drain plug right near the axle output.
The factory doesn't have a recommended change interval for manual transmission fluid but personally, I would recommend around 100K.
Sep 16, 2010 at 1:56 AM
