Camshaft Position Sensor
MISSTEE704
I need to know how easy it is to fix a camshaft position sensor, and where it is located in the car?
Jun 22, 2009 at 5:57 AM
JDL
  • 16,098 POSTS
Hello, should be located on the rear of cylinder head. The code doesn't tell you what to replace, only that the computer thinks there is a problem on that circuit. I have heard of the crank or cam sensor causing a code to set for the other sensor. You probably need to check both.
Jun 22, 2009 at 6:10 AM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_neon_camshaft_sensor_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_neon_cam_sensor_11_1.jpg
Doesn't look too hard to me.
Jun 22, 2009 at 6:59 AM
SHAMEKA CARTER
I don't know if it's the crankshaft position sensor now or what?
Dec 9, 2020 at 12:31 AM (Merged)
JIS001
  • 3,412 POSTS
Hello and welcome to 2CarPros. That code can be pretty tricky to diagnose. Inspect the wiring harness. They get very brittle and sometimes short out. Look around the passenger side axle. If the harness is dangling it could be rubbing on the axle causing a short with no start. If the harness is good then the crank sensor is faulty. With a code like this I always replace both cam and crank sensors. The crank sensor is no more then $30.00 but really tricky to get to the 10mm bolt when you crawl under the car.
I would recommend replacing the crank sensor since that is the culprit with the vehicle stalling out randomly and no starts if a visual inspection of the harness is good. But as stated earlier, I did have one Neon shorting out to the axle and actually caused a fuse to blow out. So check fuses also. If blown out defiantly a harness shorting out. Let us know on the fuses and harness please.
SHAMEKA CARTER
Thank you. I will get a crank sensor and check out the wiring.
JOH HUEBNER
My 1999 neon 2.0l dohc broke the timing belt and ruined the head. I got the new head installed no problem but it wont run. Its has spark and compression, but the fuel injectors wont let the gas through. I changed the cam position sensor and installed the original magnet ring still nothing. What controlls the injectors?
  • 31,937 POSTS
Have you scanned for any unresolved fault codes as yet?
JOH HUEBNER
I can not get my obd11 scan tool to work or get codes.
JOH HUEBNER
Im wondering a if its the pcm or ecm .Maybe the crank sensor. I checked the injectors they work electricly when 12v put to them I really dont know what to do next.
MELVINDOO92
  • 35 POSTS
Can someone tell me where a cam sensor is located on 1998 dodge neon 2.0 sohc?
Dec 9, 2020 at 12:32 AM (Merged)
CARADIODOC
  • 34,413 POSTS
Driver's side of the cylinder head.
MELVINDOO92
  • 35 POSTS
do u have a picture that i can go off, cuz im not an expert with cars.
CARADIODOC
  • 34,413 POSTS
You can find a picture of the sensor on rockauto.com to see what it looks like. What kind of problem are you having?
MELVINDOO92
  • 35 POSTS
no spark, no start.
CARADIODOC
  • 34,413 POSTS
Got it. The cam sensor can cause that but how did you arrive at that conclusion? The crankshaft position sensor is also involved. If the timing belt jumps two teeth, the Engine Computer will shut the engine down to protect the valves. It does that by turning off the automatic shutdown relay. That removes the voltage to the ignition coil pack, injectors, and a few other things.
There should be a diagnostic fault code related to which sensor has failed or if the two are out of sync. Chrysler makes getting those codes real easy. Cycle the ignition switch from "off" to "run" three times within five seconds without ever cranking the engine, then watch for the codes to display in the odometer. Holler back with those codes.
MELVINDOO92
  • 35 POSTS
well my buddy came over and hooked his scanner up to it and it showed that the pcm wasnt gettin a signal from the cam sensor.
MELVINDOO92
  • 35 POSTS
it was gettin a signal from the cam sensor just a bad one
MELVINDOO92
  • 35 POSTS
alright i put the new cam sensor in and now when i got 2 start it, it doesnt even turn over, it clicks once then nothin. any suggestions
CARADIODOC
  • 34,413 POSTS
That sounds like battery connection problems. Turn on the head lights and watch how bright they are. Watch what happens to their brightness when you try to crank the engine.
MELVINDOO92
  • 35 POSTS
yup it was just a untightened nut on the battery terminal. i tightened it and the car fired right up. thanks for the help, well appreciated
TOM 2
I have a 1999 Dodge Neon, Long story short check engine light came on ran scanner and it comes up cam position sensor faluty. Took old one off and went to all local auto part stors to enclude the Dodge dealership and the old part is different than what they all offer. The cam sits out about a 1/8 of an inch and the old sensor was recessed for that but the new ones are flush. Any clue?
Dec 9, 2020 at 12:33 AM (Merged)
SERVICE WRITER
  • 9,123 POSTS
I've run into re-designed parts that just didn't look right. I have also found on a several Mopar application that you need to buy a new connector with it. IF the dealer said that the one, then as long as it fit, I'd go with it.
